upsmannj
Anyone with a BCD436/536HP know how to FINE tune the NJICS? Most of the transmissions are distorted and barely readable on my 436HP. Thank you for the HELP.
Would getting the PROVOICE upgrade on the 436 make a differance?
Thank you for the Info.
best thing for that simulcast distortion on the njics is block out transmissions from all the towers except for one of them, so what i do is stick the antenna my scanner came with through a hole in the side of an empty paint can near the bottom, or maybe surround the antenna with a similarly shaped enclosure with cardboard and aluminum foil. problem solved.
