For those of you have experimented, is there any good reason not to just use an external power supply / wall wart to power this scanner other than having the bundled up 120v power cord hanging down uselessly?
I know the internal supplies can get hot and added heat in the case isn't a good thing, so why not just use a 12-14 volt wall wart instead? Are some of you doing that? If so, what is the mAh requirement for such a wall wart to comfortably run this scanner at a reasonable volume with full backlight?
