MTS2000 Tone Problem
beaker7
Boise, ID
Hey y'all purchased a MTS2000 VHF and it having problems with transmitting tones. In the CPS I will have set a channel to both Receive and Transmit a DPL of 131. It is receiving correctly with a DPL of 131 but its only transmitting a DPL of 023 no matter what DPL I set it to in the CPS. Ideas?
cmdrwill
So Cali
Wrong antenna causing RF to get into radio and distort the DPL TX wave from.
Or the transmitter is OUT of alignment.
Someone jammed in a 'code plug' from a different radio.
And you did check if the software has an INVERT setting for the DPL.
beaker7
Boise, ID
Correct antenna (OEM Moto VHF)
Codeplug possibly although s/n matches (granted doesnt mean it hasnt been changed)
and oddly the INVERT setting seems to have 0 effect checked or unchecked.
So maybe alignment?
Other than that any other possible ideas? and Thanks!
cmdrwill
So Cali
modulation compensation?
Part of Alignment and Calibration.
And we have seen first hand many radios that have the calibration values all messed up.
So, first thing is to look at the TX DPL wave form on a service monitor. I'll bet the TX DPL IS distorted. The TX PL will probably look OK.
RFI-EMI-GUY
One way to determine this would be to probe the DPL signal ahead of the modulator to see if it decodes properly.
If I recall correctly, 023 is one of the normally difficult codes to modulate because of a long string of data with same polarity, maybe that makes it easily susceptible to falling by a distorted signal.
Sent from my SM-T350 using Tapatalk
