From the manual:
To clone a scanner:
1. Connect the two scanners at their PC/IF ports.
2. Turn on both scanners.
3. On the source scanner, press PGM.
4. Press the GLOB softkey.
5. Use the 4-direction keypad to locate the Clone
Send option.
6. Press SEL to transfer data.
NOTE: Working memory and global settings are
transferred but not V-Scanner folders. The target
scanner's working memory will be overwritten. In some
cases, the CCDump output may interfere with cloning.
To turn off CCDump:
1. Press PGM.
2. Press FUNC and then the GLOB softkey.
3. Use the 4-direction keypad to locate the CCDump
option and change the setting.
4. Press the Save softkey.
Shawn
