Trbo Question
celltech25
Benton
I know its techincally not supportedbut has anyone had any sucess or a way to alert multiple radios in TRBO
Would like to alert 15 to 20 radios as a Group Call with an alert tone sorta like wehave done for years with qc2
N1GTL
CT
Flexible RX list for turning on and off. RX Group list can do it to keep it active at all times. These are CP and LCP solutions. You can get tricky with auto scan if it is stand alone or IPSC. A little more information about the system is needed.
celltech25
Benton
I think i got it right based on what you were saying
I setup a ID as a CAP PLUS channel
went to my sites told them to listen to rx group 1
put that channel in the list
and can send a txt message to it, Wish they would just let you do a call alert
N1GTL
CT
Create a separate talkgroup ID for the radios you want to receive the message.
Add that talkgroup ID to the RX group list
Assign that group list to the subscribers you want to receive it.
Someone has to have a radio capable of transmitting on that talkgroup ID. When they do, all radios with that RX group list assigned will receive it.
I read this as you wanting to do a voice notification to certain radios. I'd have to research a little on group texting as I've only used third party software. You can set up canned messages but I'm not sure about a "group list" for people they need to go to. Maybe someone else can chime in.
celltech25
Benton
group
Yeah Voice works Fine
I can do a Group SMS to the talkgroup and it alerts..
Going to test it from a PC next
WOuld be nice if MOL would just allow Group Call alert
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
You can enable a receive alert on the talkgroup you are using for notification. I can remember what types of noise it makes, but there were some choices...... TT
celltech25
Benton
Alert
Yeah i have an alert set, I just wished u could do call alert and not sms
sms requires you to click and read the msg to get the alert alarm to quit a call alert will just stop
Firebuff880
Boynton Beach, FL
You have it correct. We deliver NWS Warning, Staff information, Situational updates, and for some college campuses copies of the mass notification messages. With 2.8.5 you can even do a group message and request confirmation from some users. Aka: supervisors.
N1GTL
CT
You can. In CONTACTS where you set your talk group ID's, check off CALL RECEIVE TONE and under the RING STYLE you can pick ringer 1 through ringer 10. You would make this change to the talk group ID you have set up as your notification.
Aaron_B
You can mimic a quick call in LCP. All you need is an xpr7550 and when you key up if the keypad is programmed to be "hot while transmitting" then when you press the PTT you can press a number on the keypad of your xpr7550 radio which will send out a loud DTMF tone to all users on that talk group. After the tone is sent release ptt and then ptt again and proceed with your announcement.
