XTS-1500 battery chirp?
RadioChief55
Our XTS-1500 portable radios show full battery but when the radio is keyed the battery level indicator flashes with no bars and the radio chirps when we let off the mic, then the battery level goes back up to full. Batteries are fairly new. Any ideas?
Thnaks
duffy109
Greater Cleveland Ohio
Thnaks
Are you charging them long enough? In a charger that reconditions them? Ever have them reconditioned on a Cadex?
rescue161
KE4FHH
Hubert, NC
When was the last time that they were aligned? Adjusting the low battery threshold is part of the alignment procedure. What type of batteries are being used? If they are Motorola batteries, what is the date code? Are they impres batteries? Were they initialized and charged in an impres charger? What is the firmware on the chargers?
N4KVE
PALM BEACH, FLORIDA
That's usually an indication of a weak cell. While receiving, the battery shows all the bars, but when trying to transmit, that weak cell causes the good ones to strain, but they can't keep up.
K2NEC
Terrible explanation of why a weak cell triggers the low battery alert.
Where is your explanation? Unless you have something better to add don't criticize others.
What rescue161 asked is what you need to answer. It is probably that the batteries are dead and either won't hold a charge or aren't being charged long enough. That is what happened to my XTS5000 battery so I bought a new battery and problem solved.
