Trunked Motorola P25 II
BlueDevil
WA
I am setting up my first Trunked System on my Uniden BCD996T. It is a UHF Motorola P25 II System.
I am making some progress however I am not sure exactly what I am doing. I don't want to add too much to the system where I am hearing everything (i.e. Public Works) but I want to make sure I get the Public Safety Talk Groups.
I believe all the information I need is listed on this page: Umatilla County / Morrow County Trunking System, Pendleton, Oregon - Scanner Frequencies
However I am not real sure on which ones I need and which I don't.
Any suggestions or recommendations?
kma371
Make sure you are entering it as a Motorola system and not "P25." While it has P25 modulation, it isn't a true P25 system and is recognized differently by the scanner programming.
And which ones you need vs which ones you don't will depend on what you actually want to monitor. If it were me, I would just listen to the agencies that cover the area I live in, or, those which border the area I live in.
UPMan
In Memoriam
Arlington, TX
Based on the link, it is a fully analog Motorola UHF system. In addition to the frequencies, you will need to also enter a custom band plan with the information provided on the RRDB page. I believe if you use software (Freescan, ARC, etc) and import from RadioReference, all the correct settings will be applied.
werinshades
Chicago , IL
I did see that afterwards, but couldn't delete the post.
jonwienke
More Info Coming Soon!
VA
Same thing applies. If the system is Phase II, he would need a 996P2. The 996T cannot decode P25 Phase II--996T lacks the necessary hardware.
UPMan
In Memoriam
Arlington, TX
True. But, the OP is not talking about any kind of digital system (despite the thread's subject). The scanner he has will work just fine on the system he references.
BlueDevil
WA
I am not sure why I thought it was a P25 Digital System. It is not listed as digital and definitely doesn’t sound digital.
I am using ProScan to program my BCD996T scanner. What system type would I want to select for this trunked system?
kma371
See post 2
BlueDevil
WA
See post 2
Thanks!
I have the system set to Motorola Type II/P25
The only options in the ProScan programming are: Conventional, Motorola Type I, Motorola Type II/P25, EDACS Wide/Narrow, EDACS SCAT, and LTR.
