Fairfield Co and Lancaster
firecatohio
Logan, oh
So I believe the city of Lancaster did a little switch up? They switch frequencies, DPL codes or over to marcs? Anyone know what is up?
Sent from my SM-N950U using Tapatalk
firecatohio
Logan, oh
This marcs is one twisted beast.. I set up a bank on my scanner with every site in Ohio with ID search.. finding all kinds of stuff.
WeldGuy
Canal Winchester, Ohio
SO cruisers being fitted up this week for MARCS. No FD on MARCS yet.
Will Fairfield County MARCS be moved to this thread instead of Fairfield County thread above???
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
We have submissions that I'd like to get confirmation on.
1. "Lancaster has changed over to 453.725 P25 NAC 28F or 247"
2. "Fairfield Co Sheriff is now on MARCS-IP TG 16501"
Can we get some confirmation from the regulars?
Tnx
Mike
mtindor
OH/WV DB Admin
I have heard some units on 16501 that sounded like the SO.
Thank you. I'll go ahead and add 16501 as Fairfield Co SO.
Hopefully somebody can confirm whether or not Lancaster PD has changed from 453.725 PL 131.8 analog to 453.725 P25 NAC 28f or 247
Mike
mtindor
OH/WV DB Admin
We had a submission suggesting that they switched to P25
453.725 NAC 28F P25
You might want to add it as a P25 freq with no NAC until you can verify that the submitted NAC is correct.
It is listed in the DB now, but with the 28F NAC.
Mike
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
The switch can't come fast enough. A large fire in Bloom Twp and they can't talk to mutual aid Columbus units.
Bloom Twp Fire has 800 MHz radios capable of talking to Franklin County (and Columbus) units; have had for years and use them regularly.
Sounds like an operational brain cramp on someone's part.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
I thought all MARCS was 700 -800 mhz?
Lancaster is not on MARCS. They're using the same UHF frequencies they have had for years but with P25 instead of analog.
W8RMH
Feed Provider Since 2012
I have heard a few tests on 16501 and 16502. A lot of dispatch type traffic on the Interop TG 54542.
I have a yagi pointed at Lancaster, I will setup their frequencies as digital and see what I can catch.
