Scandude65
I have tried the freq 461.675 and it is not working anymore, I am wondering which freq they are using now for bus dispatch. Thank you
Wow! You jump in on a Colorado forum when you're not even from here and can't be more accommodating? This site and the members on it are supposed to be helpful for others seeking assistance, not to be condescending!as with most of everthing else some schools have moved to the trunked systen. edacs standard with esk. frequeccies and tg's are in plain sight when you click on the trunked system left side under the map. the next question your most likely going to ask will be "will my scanner pick it up" the answer is "i don't know" what kind of scanner you have. i did find one uhf frequensies that could be also what your looking for, i did find one uhf frequency : 464.374.
good luck.
Have you tried these...Thank you, I have the right scanner it was programmed by Curt but I can't seem to find the tg for DPS Bus Dispatch, all I see is the Security talk groups ?
I think they might be on a NEXEDGE system 452.2750Mhz. RAN 6. WPRM567.
Hope this helps.
Given the current social/political climate surrounding schools, I would not at all recommend this. Unless you want some unwanted attention from law enforcement.and if all else fails, call the school and ask yo talk to the bus transportation manager, ask who ever answers if they have changed the frequency on the bus radios. who knows you might get lucky. all they can do is hang up on you.
If you don't know the answer(s), then why are you posting a reply?
452.27500 WPRM567 RM 79.7 PL Den Sch Ops1 School Operations 1 FMN Schools
453.73750 WQPZ258 RM 072 DPL Den Sch Ops2 School Operations 2 FMN Schools
461.67500 WPRM567 RM 110.9 PL Den Sch Bus1 School Bus 1 FMN Schools
464.37500 WPRM567 RM 110.9 PL Den Sch Bus2 School Bus 2 FMN Schools"
453.5000 DCS 565 with Kenwood Fleetsync. This appears to be their primary channel.
453.7375 DCS 532. Appears to be a secondary channel.
