Constant squelch on Icom F-121s
DODGEIT
Sarasota Florida
I have 2 Icom F-121s radios. I recently brought them out and put them on the bench and hooked them up and powered them up. They transmit fine but using either one of them they have constant squelch. I just used the software to program them up so maybe I set something wrong. Anyone familiar with these radios could you share your knowledge.
12dbsinad
First thing to check is the squelch level in set mode. Make sure it isn't set to 0 or a really low value. Do you have them hooked up to an outside antenna, dummy load, etc? If it's hooked to an outside antenna, try disconnecting the connector completely from the radio and see if the squelch goes away.
DODGEIT
Sarasota Florida
I did as you suggested and found it at 1. So I adjusted it to 5. No luck. Tried 10 still no luck. I am at a loss as to why they are doing that. Both radios same thing.
12dbsinad
Glad it worked. Anything below 15-20 or so and it'll just open the squelch completely. Usually I find 80-100 is a ideal setting.
