How do I clone two BCD325P2? The menu has a Wired Clone tab but what to do for the jumper wire.
I've never had a need to try it, but Wired Clone is an option in the menu for the 325P2. Select that option, then set each scanner to Master (the source) or Slave (scanner to receive the programming).
You would need a cable with mini-USB on both ends. Found this
one; others show up if you Google it. Connect the cable to the two scanners, and set the clone options.
Frankly, though, I'd simply use software, such as FreeSCAN to 'read' your source radio, then write the configuration FreeSCAN got from the first scanner to the one to be programmed. That would also leave you with a backup file, just in case. Plus, once you've read the 'master' scanner to the software, then you could make any desired tweaks, such as modifying the opening screen text, before sending to the other unit.
The clone procedure is not listed in the 325's manual (at least not in the *.pdf version I have), but should be basically the same as listed for the 396XT. You can find that on the Easier to Read
manual.
