In reference to the below instructions from RR, how do I set my scanner to record so I can use the "REC" output on my radio feed? I have a BCD536HP
"Uniden scanners must be programmed properly so that each channel is set to Record = ON to allow audio to flow to the Rec or Tape Out jack. If you skip this step, the feed will not get audio from the scanner on those channels.
Newer Uniden scanners label the line output “Rec” (for Record out) and is located on the rear of the radio and is color coded green. The Record output needs to be turned ON via the software to activate it for use"
