CDM1250 F401 fuse
BN203
Springfield, OH
I found my no power issue. The F401 fuse on this used radio is missing. What is the risk of just jumping without replacing?
From the service manual:
Fuse F0401 prevents damage of the board in case the FLT A+ line is shorted at the control head
connector.
It also says:
Note: Fuse is part of PCB
In case fuse is blowen, replace
it with R0410 P/N 0662057B47
Fuses are there for a reason. You could bypass it and be just fine, or down the road you could have a fault and end up burning up the circuit board trace.
Fuses are cheaper than new circuit boards.
n1das
Nashua, NH
Why is the original fuse missing in the first place?? The original fuse might have cleared due a fault and that fault may still be present. The risk with jumpering the original fuse is that it could cause the magic smoke to come out if a fault is still present. The fuse is there for a reason. You could do some ohmmeter checks to verify that there isn't a dead short downstream of the fuse.
Good luck.
Sent from my Nexus 6 using Tapatalk
