Any New LWIN Sites
teebee
Lake Charles, LA
Has any new LWIN sites been added recently or any plans of any new ones mainly in the southern areas of the state?
Sometime back someone posted there was supposed to be a new site placed in the Raceland area.
teebee
Lake Charles, LA
Really find it kind of odd that they are putting one up in Thibodaux since there is one so close in Gray, and same for Galliano with one close by in Larose. But of course they put one in Baldwin which is only 10 minutes away from the site in Jeanerette.
shew
PIERRE PART, LA.
what happened to the baldwin tower ....i was catching it here in pierre part for the longest...now the last couple of weeks i hear nothing on it...no strength bars
red8
denham springs la.
Southern University PD. is new. I found it today on the database, Fire District 2 in St. Helena is also new. And is in the database also. I would have to go back to look them up for you.
jim202
New Orleans region
In some cases the reason for new towers is not coverage but capacity. The towers out in the rural areas do not have that many voice channels installed. It doesn't take but one roamer from another region listening to their home dispatch talkgroup to take away a voice channel from the local users.
If you look at the main highways, this is the place where the roamers from outside the region will normally be traveling. Planning on the state wide system has in general been done very well. You will find that in some regions, the system looks like it is way over built. But in reality, it has been installed that way to take into account the large numbers of users that either live in these regions or travel through those regions on a daily basis.
Probably the prime region for this high roamer traffic is in St. Tammany Parish. It is a bedroom region for a large number of people that work in other areas. As a result, the traffic is on the high side for the system with these people coming into this area for the night or weekend. It can drive your scanner crazy if you don't lock out all the external talkgroups your not interested in.
If an incident takes place in the normal coverage area of these commuting roamers, you hear that traffic on your local towers if you have a roamer there. Yes it does chew up the limited voice channels available in many of the regions of the state.
teebee
Lake Charles, LA
Any update or timeline on the new tower in Thibodaux. What ever happened to the Raceland new site someone mentioned a few months ago.
Spec605LA
Statewide Radio Jedi
South East Louisiana
Thibodaux is still in the planning phase. Raceland has not been discussed in some time. Bourg should be online soon.
