P25 operation
W
W4ZMJ
Guest
I'm going to ask this question and I probably should already know the answer first question if I have to p25 radios in conventional mode and I want to use them to talk to each other the default talk group ID I believe is one do both the talk group IDs in conventional have to be the same for the radios to talk to each other I believe there's no way to cut the talk group ID off. and the NAC 293 as default I don't think I can cut that off either basically what I'm wanting to do just transmit p25 without any NAC or talk group or am I basically stuck with the default settings
Sent from my LG-H343 using Tapatalk
N1GTL
CT
The term "talk group" is generally referring to in a trunked system. Are you just trying to get the radios to talk to in other in simplex mode? NAC F7E is the P25 equivalent of CSQ.
293 is the default on APX radios generally but there is no reason you can not leave them at that for a simplex conversation. There are no "talk groups" on P25 in simplex or even in a conventional repeater.
W
W4ZMJ
Guest
Ok then. Didnt know if you had to set up a talk group for each radio you was communicating with but you have to have at least the NAC set for each radio you can't turn that off can you
marcotor
I ♥ÆS Ø
Sunny SoCal
Better tell anyone on the P25NX system there are no talk groups on conventional P25. I am sure they will disband immediately knowing this information. :roll:
F7F tx, F7E rx though this will unmute to anything and he would be better off using a 293 NAC or other.
