DSDPlus 2.98 Fast Lane Release Notes
blantonl
Founder and CEO
Staff member
Super Moderator
San Antonio, Whitefish, New Orleans
Code:
DSD+ 2.98
Setup
  The DSD+ 2.98 files should be copied to an existing DSD+ 1.101 or higher folder.
  If you do not have a DSD+ folder set up yet, go to DSDPlus.com and download
  the most recent public version of DSD+ (currently 1.101) and unzip all of the
  files to a folder on your PC.  We recommend using C:\DSDPlus
  This text file describes any additional features that have been added to DSD+
  and its supporting programs since the 1.101 public release.
DSD+ 2.98 Changes
USA License Data
    March 16, 2018 FCC data was used to create updated FMP/FMP24/FMPA-compatible CSV files.
    Per-state files are here:
      https://mega.nz/#!kgpEUSqB!IoiPVHZ9QynndlV5buzcsoZAKb88AQGpXCyPNPsFgwA
    A single USA-wide file is here:
      https://mega.nz/#!BtYwEDaT!dC-8XgSTDVtNbC7IYEtHOsuS1x3fwOjqxcBBJuPVs4U
    The DSD+ 2.10 notes explain how to use these files.
    D-Star voice and link control decoding improvements.
    Fusion voice and link control decoding improvements.
    NXDN: Additional AVL messages decoded.
    DMR:
      Some changes to TIII processing.
      Additional TIII messages decoded.
      Some changes to voice link control decoding.
    P25: Neighbor status (Networked, Failed, etc.) display added to console log and event log.
    Added fixes for NID prefix handling.
    CC/rest hunt changes; On loss of control/rest channel,
      CC DSD+ will load and tune all known site frequencies.
    Some changes made to audio AGC logic.
    In DSDPlus.frequencies, "?" allowed for unknown OTA channel numbers,
      TX frequencies and RX frequencies.
      Examples:
        Con+, 123, 1, ?, 454.6125, 0.0, 0
        Con+, 123, 1, 7, ???.????, 0.0, 0
    In the event log, DSD+ will report these as records with incomplete fields rather than as errors.
FMPA 2.16
    Changes to NID prefix support.
FMP24 2.35
LRRP 1.13
    Stability improvements.
WX4JCW
Stow, Ohio
Has it been sent yet
Sent from my iPhone 8 using Tapatalk Pro
Jason WX4JCW
Unication G4, BCD536HP
WX4JCW
Stow, Ohio
ok i went ahead and donated again,i think mine expired, if it did not oh well he deserves it
D
DaveNF2G
Guest
As has been explained more than once in various threads, FastLane is sent sequentially (either in order of subscription or alphabetically, not sure which) via email service that has limited broadcast capacity.
CanesFan95
FL
Got mine this morning. I'm noticing on a NEXEDGE48 trunking system that sometimes the Pri column on the CC Channel Activity window will show "Alias" for some voice calls instead of showing a priority number like 50. Other voice calls will show 50 in the Pri column. If you press the spacebar to hold on a talk group, anytime the Pri column shows "Alias", the voice call isn't followed and you don't hear the transmission. Only if the Pri column has a number will it trunktrack and let you hear the audio.
WX4JCW
Stow, Ohio
Got it last night
Jason WX4JCW
KE7VJW
Tucson, AZ
I downloaded it this morning and got a Trojan for my trouble.....luckily windows defender found it and warned me before any damage was done!!
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
Windows Defender asked me if it was OK to send the archive file to Microsoft to study it, but it didn't say there was anything wrong with it. What was the name of the trojan discovered?
KE7VJW
Tucson, AZ
Sorry it took so long to get back.
The Trojan is: JS/FLAfisi.D
KE7VJW
Tucson, AZ
I doubt it. I ran all of the executables that came with the 2.98 update through virustotal.com and no viruses or trojans found.
Ok good deal! All I know is that I got the Trojan named when I downloaded the new fast lane update. It came at the same time, was attached, wasn’t attached. I don’t know. Just reporting what happened to me. Thanks!
D
DaveNF2G
Guest
I searched that name and every site that talks about it starts with a description written in very poor English. Makes me wonder if anybody knows what they are talking about.
dlwtrunked
Norton Security found it clean.
I wouldn't rely on Norton, I scanned a computer running Norton and found 110 infections with AVG,a free antivirus.Try scanning DSD with that!
zerosix
I still haven't received it and I'm pretty sure it hasn't been a year since my subscription. I understand the sequential sending. However, it should have been arrived by now right?
