Unity portable squelch?
TDR-94
How does one determine the squelch setting for analog conventional channels if the XG-100P has no squelch adjustment setting? Is it locked to a setting of 9?
kb4cvn
Silent Key
Nowhere near a paved road, away from the maddening
Design limitation on the radio built by Harris Rochester (NY).
Basically the Unity XG-100p is a Harris AN/PRC-152 Falcon-III radio with the following changes:
  • Battery moved from bottom to back (allowing the use of the P7100 style batteries)
  • Display changed from a IR version for NVG use, to a visible light model.
  • NSA Approved Type-1 Cryptographic module replaced with a NSA Approved Type-3 module, supporting DES and AES encryption formats.
  • Main circuit board altered, removing the 30-88 MHz band, and adding in the 700/800 MHz band.
Harris (Rochester) essentially took an off-the-shelf Green Radio, tweaked it a bit, and repackaged it for public safety use. Radios after that were designed by Lynchburg, who have better technical expertise in public safety radios.
TDR-94
How is the squelch threshold determined by the radio? It it just set to a factory preset level?
Interesting background on the design by the way.
