TRI-152 vs TCA 152a
E5911
the lower desert
H all
Saw both radios on Airsoft forums, The tri radio appears to be a UV5r in a fancy package with a great battery. Not sure about the TCA. different display. Will take a GPS board or something,
Does anyone know about the TCA 152? It does not appear to be a beofeng clone
Just curious
rescuecomm
Travelers Rest, SC
The TCA-152 is the latest version and supposedly can use the mbiter accessories without mods. It has the aluminum housing. The TRI-PRC-148 is about the same but ships with a Thales battery and is more expensive. These radios don't have any type approvals so use them at your wn risk. Someone on M4Carbine.net has a writeup.
Bob
baltimorecs
Baltimore, MD
These radios are based on an older model made by a company called Baojie. I made some programming cables for one of the PRC-152 clones made by Triumph Instruments (TRI.) It used the Baojie software to program them.
There is a Facebook group dedicated to the radios here, which is where I found the info to mate the USB to a real PRC-152 cable for programming (pinouts are all different.)
BigLebowski
Piedmont NC
They are both glorified baofengs and perform as such. The TCA is the better radio of the two though.
laythrom
Warren, Ohio
Any chance you recall the FB group where you got the pinout information?
