Motorola MaraTrac
TexasMale
Port Neches, Texas
I have two Mara Trac radios Brand New one box never opened, I opened one of them just to see what was in the box. How do I tell if they are VHF or UHF and any other thing I need so that I may sell these Radios.
Thanks for your help
RadioGuy7268
PA
They have a limited audience. They are wideband radios, so they're not really going to be worthwhile in any part 90 service.
Hams might be interested in them for the higher power output, but most people seemed to be focused on digital modes, so you're even playing into a limited audience there.
Ebay shows recent sales for VHF units going anywhere from $50 to $150.
MSS-Dave
Generally Central Florida
That is going to depend on what frequency band the radios are on and their condition. Complete used radios can get between $100 and $200 depending on condition and demand. You said you had one brand new in the box so that may bring a little more but they are fairly old radios. The only real advantage is they are programmable with software.
If you can post the model number of the radios you have that would be helpful, there may even be somebody reading this thread that would be interested in buying one.
FFPM571
Nashvillle
Low band Matatrac is worth more to the Hams as they can be modded for ham use easily...
k9wkj
where they make the cheese
i run a A9 head MaraTrac on 6M in my van
someday i hope to find a bottom split for 10M
you cant tell what split the lowbanders are by the model #
one must look at the part # of one of the boards inside
all of this is talked about on the previously linked Repeater Builder site
fabulous old radios
I have been able to give them modded firmware to get a handle on the power and deviation control issues they have when moving to the ham bands
TexasMale
Port Neches, Texas
these two radios are 110 watts Mara Trac radios the Frequency 42.0 to 50.0
Radio # 1
Model = T81XTA7TA7BK
Serial = 776TWG0909
Radio # 2
Serial = 776TWG0908
parma,ohio
fabulous old radios
i have a 36-42MHZ Maratrac hard to find a buyer and shippiing it would cost a lot
gargamel1901
fabulous old radios
I'm guessing you meant a CH that resembles an A9. Maratrac heads (HCN1052 or 1089) are not interchangeable with X9000/Spectra lines.
As for 6 and 10 together on one drawer, a T71 X9000 will do that, and then some.....
No issues with deviation or PA output going off the rails when programmed for OOB operation either.
MSS-Dave
Radio # 1
Serial = 776TWG0909
Radio # 2
Serial = 776TWG0908
So you have the more desirable VHF low-band radios that can be converted for 6 meter Ham Radio use. Post them on the for sale section of radio reference or put them on eBay. Shipping one of those is going to be around $30 in the US UPS Ground.
Project25_MASTR
Millennial Graying OBT Guy
Texas
Not to mention to the right buyer, they could go into commercial service as the low-band radio supply is becoming more difficult to come by...especially since low band was not required to narrowband.
k9wkj
yup ive had my head in other places
C9 heads
99 channels of awesome
and both of my running 6M MaraTracs have squelch controls!
i like mono band radios
and ill find a 10M maratrac someday
but its true that 99 channels on 10M FM would be very silly:D
RFI-EMI-GUY
Florida DOT uses those radios in the 47 MHz band. The programming cable is same as a Maxtrac with the square bud box and RJ connector. You plug it into the drawer unit.
W5KVV
S.E. Oklahoma
Easiest way to tell a low split Maratrac is by the HUB/TANAPA #. HUB1114A is the one you want.
As long as the radio hasn't been molested and the sticker hasn't been scraped off that is. Other than that you'll have to open it up and look at the boards or read the radio.
I have a stack of Maratracs in the mobile on 2m 6m & 70cm. Fantastic performers. I've been looking for the low split to finish my stack for years. They're a rare bird.
Of all the Maratrac radios, the 29.7-36 meg split is the rarest, and most valuable.
