W5RGP
is there anyway to export a Trunked system from ezscan to maybe a excell spreadsheet or .CSV file
or atleast export a list of the tg's and Freq's
No. Unfortunately there isn't.
Load one of the 30-day free trials of a software that have export capabilities. Then download the scanner's data into it, and export.
No third party apps read the trx’s
I don't see any need to use exporting as ezscan handles the imports and moving around just fine, you need to retrain your brain to ezscan if you were using other software.
Read my original post
I have a large nxdn system that I built from scratch in ezscan for all of my trx’s
I now have nxdn on my uniden 436 and 536 I did not want to have to manually re enter 100 freqs and about 20 sites and over 150 tg’s
So I was looking for a way to export it so I could import it into sentinel or proscan
If you don’t have an answer to my original post and just want to be sarcastic just keep your pie hole shut
10-4 ??
I wonder if not allowing third party support since the PSR-800 is driven by fear that the FCC would go after GRE/Whistler for "easy cellular modification", if a third-party found a way to receive cellular by directly modifying the files on the computer.
Whistler considers obfuscation to be the same as encryption, so Whistler would likely try to shut down any third-party program for just reading their scanner files directly, legal or not.
73 Eric
