OKC area NXDN ...
plaws
E Hawkesbury Twp, ON
Are there any active channels? I have entered what I found at https://digitalfrequencysearch.com for Cleveland and Oklahoma Counties, but so far the only thing I am seeing 853.1375 (The City of Midwest City) light up with a RAN. Since these are entered as conventional and then set to digital only by me to prevent analog falsing, can I assume this is really a NXDN channel?
I'm sure https://digitalfrequencysearch.com makes a guess based on the licensee's emission type but is that an exact match? Or could the same emission type actually be one of several DV types? My 436HP has all the keys, so I assume it will decode whatever is appropriate.
plaws
Looks like they are just best-guesses at that site. On 461.9000 and 463.5000, both licensed to Chickasaw, I get Color Codes and slots, so pretty clearly DMR there ... TGIDs, too.
nd5y
Wichita Falls, TX
There is no way to tell besides direct monitoring. Sometimes more emission types are on a license than are actually used and sometimes they use emission types that aren't on the license. The same is true with frequencies.
plaws
I figured as much. I was really hoping that someone was going to say "yeah, listen to <some frequency>" but alas ....
I've been logging on my BCD436HP using ProScan today and 853.1375 and 806.1375 are both showing up in ProScan as "NX4" with "R 1" in the Tone column (which is a RAN, I gather). Maybe it's really a NXDN system. The signal is always there on 853.1375 so I put a negative delay on it so it would start scanning every few seconds in case that signal was real. Maybe it's a control channel? Sentinel hasn't been updated to do anything with NXDN but maybe ProScan has. I know basically nothing about NXDN ... guess I need to read up. :)
HogDriver
Oklahoma City, Ok.
I drove out to the gas plant in Canadian County yesterday to see what i could find...it was a sleeper!, I guess because it was Easter. I then drove to Enid and picked up all 5 LCN's and also logged an undocumented TG which might have been PD. Its number was 31103 and also logged a RAN of 1.
HogDriver
Oklahoma City, Ok.
You might try your local county jail - I've heard they run NXDN in simplex...but I can't verify that.
On a clear night, I can hear Enid...it's a little choppy with the 536.
The Devon/Cana Gas Plant ( https://www.radioreference.com/apps/db/?sid=8591 ) comes in ok for me, but very little activity.
We're you able to log all the LCN's for the gas plant? Also note the license actually shows 5 freqs.
wx5uif
Broken Arrow, OK
From what I've found in enid 31100 is Life EMS. I'm thinking all the 311xx is releated to EMS.
The 1000x TGs are PD and animal control.
KAMO power has a large system in OK and MO that I've been trying to work on getting the LCNs correct with the licenses.
daddyjohn
Where is the easiest place to find the frequencies that KAMO uses in and around southwest Missouri? Thank you.
Sent from my SAMSUNG-SM-T337A using Tapatalk
mam1081
Next to a scanner...
Yes on the LCNs for the Gas Plant - they are submitted and available in the database (click on the site name). Listing again here, they are:
CH ID Frequency
111 451.375
139 451.725
511 461.375c
675 463.425
As for KAMO, yes - we should work on figuring out that system...it's very large. I can only hear the Shawnee site typically. I did find some new freq for that site and think I submitted them, but they aren't in the db yet. They are:
Shawnee - Site 3, RAN3
153.650 - LCN10
153.725 - LCN11
152.945 - LCN12
153.110 - LCN13
Neighbors 4 (CC10), 10 (CC40), 29 (CC125)
plaws
153.650 - LCN10
153.725 - LCN11
152.945 - LCN12
153.110 - LCN13
I am in East Norman and can probably hear this node. Will take a listen later today.
Is there any documentation on how the NXDN stuff works on the BCDx36HP? I have, through intense deduction, figured out that "NX4" is a 4800-baud transmitter and that "NX9" is a 9600-baud transmitter. Sadly, I have no idea what that means. :lol:
Unless it's changed like, today, Sentinel doesn't do anything with NXDN. I do have a license for ProScan, though, and the author has made some NXDN updates but I'm still left with not really knowing what that means.
If there aren't docs, how about a comparison to, say, a DMR system?
plaws
153.650 - LCN10
153.725 - LCN11
152.945 - LCN12
153.110 - LCN13
The only frequency that seems active is 153.6500. Progged as a conventional, I get a display that tells me Sys is 10, Site is 3, and both TG and U are 0. Icon says NX4.
So is this a control channel or something?
ProScan will let me program a system as NXDN Trunk or NXDN OFT. I see in the DB that this has 2 frequencies (though it may be behind since you have four). I'll program it as a trunked system and see what happens.
wx5uif
Broken Arrow, OK
Correct that is the control channel. The System ID for KAMO is 10.
All four of those frequencies are on the license for Shawnee. I ran LCN finder for several hours a couple days ago on the Bristow site with no hits. (Actually I had one LCN found on the CC 153.260 CCID/LCN 14.)
wx5uif
Broken Arrow, OK
Got these for KAMO today. I wish I would have looked at the site numbers...
Stillwater
151.535 126
151.6625 128
153.1925 129
153.35 125
(License shows these but no hits on LCN finder. 153.3275, 153.4925)
Bristow
151.4975 16
152.2850 17
153.2600 14
(License shows 154.6100, but no hits on LCN finder.)
mam1081
Yes, this is a trunked system. "OFT" is short of "one frequency trunk". You could think of OFT as a conventional, where there can be different users on a single frequency. The 4800 and 9600 are just different flavors/brands sometimes of trunked systems - some having to do with the bandwidth allocated (12.5k or 6.25k). You can think of the NXDN trunked systems similar to a P25 or Connect Plus DMR system - there is a control channel, all voice channels are digital, and they are (can be) networked to other sites.
On the 536, I've been just editing the favorites list with a text editor once I get enough info to actually program the system(s). It works ok...I actually prefer the GPS input in dd.dddd vs the Sentinel dd mm ss.s and easy edit several channels quickly.
mam1081
Anyone up for finding out more on the KAMO Power system? It looks huge from licenses.
I stated the Wiki page (link in the database or KAMO Power - The RadioReference Wiki)
In Oklahoma:
WQMK373: Bartlesville (151.4975, 152.285)
Centralia (151.5425, 152.465)
Evansville (153.59)
Burbank (151.91, 153.71)
Fort Gibson (151.535)
WQPC442:
Cromwell (153.215, 153.3125, 153.4475, 153.53, 153.665)
Ft Gibson (153.155, 153.29, 153.5, 153.635)
Kansas (153.0125, 153.3575, 153.68, 154.61)
WQPD952:
Henrietta (151.5275, 153.005, 153.0275, 154.4825)
Vinita (153.14, 153.3125, 153.5525)
WQPB431:
Burbank (153.065, 153.200, 153.2675, 153.605)
In Missouri:
Bolivar - WQVQ369 (single freq?)
Reeds Spring - WQPC985
Monett - WQPC985
Belton - WQPB243
Dallas - WQPB243
Butler - WQPB243
Exeter - WQPB243
El Dorado Springs - WQPC442
Elkton - WQPC442
Pineville - WQPC442, WQPD952
Gainsville - WQPD952
Ava - WQPD952
Lamar - WQPB431
Dadeville - WQPB431
Springfield - WQPB431
Adair - WQPB431
Neosho - WQPB431
