Audio is being muted on my G4
lsh1885
Orlando, Florida
I am not getting any audio on my G4, there is a button side of the radio if I push it the audio comes back but as soon as I release it the audio is muted again. What in the world did I do to screw this up?
mdsxfire
EDBM
Uxbridge, north of the river Thames
Turn off push to listen I forgot what tab it’s in I believe when u set up the system and are adding TGs it’s right above there
gibby289
Same issue
My G5 is doing the same thing.. I have checked the settings. Push to Listen: "No"
lsh1885
Orlando, Florida
Well push to listen is already off so it has to be something else. I am not sure if this means anything but in between the signal strength meter and the battery meter there is a image of a man when I turn the unit on he turns yellow but isn't turning yellow anymore.
gibby289
I figured it out on mine at least.. Hope it helps you. Under main menu scroll down to "function settings. Then scroll to 2. Receive Alert Mode. Select "Tone". That should work. When I first got my G5 it was making a loud alert tone. So I must have turned everything that said "tone" to off.
Thunderknight
Bletchley Park
There is a thread on it here...but a few firmware versions back, they changed something in CPS and the alert type for each TG in the TG setup page needs to be set to Tone. If I recall that correctly.
gibby289
Glad I could help.. I’m usually the one with all the questions... So standby...LOL
boatbod
Talbot Co, MD
Lol I ran in to this exact same issue yesterday. If you set the alert type to "silent" it mutes the audio as well as the alert. Seems like a bug to me.
JD21960
ILL-annoyed
@boatbod - No, not a "bug" or mistake. They did it as a design change that came along with new PPS controls. It seems like an "inconvenience" but it's not a bug or anything that needs fixing as the others said above. Anyone who had to reprogram 100's of talk-groups from the old PPS? yes, they were bugged.
KD2DLL
Rotterdam, New York
I am having an issue similar to this. Could someone look at my codeplug and see if they can find my issue? I can not figure it out for the life of me! All analog channels
