donrob36
Did North Cell get rebanded or is it still 800 Splinter I used to be able to pick it up not hearing anything Im in Lakeside
TY Don
TY Don
Once Mexico blocks are taken care of. Will we get a standard rebanded scheme of 851XXXX-854XXXX 12.5 spacing?
Both Uniden 796D's have undergone firmware upgrades. I think you did mention the North would be one of the last to change over.
Thanks,
Chasb
Don, when you say 12.5kHz channels, do you mean bandwidth or channel spacing? I assume channel spacing only.
Paul
Not quite understanding why the North system gets assigned the Interlieve portion of the 800 spectrum as opposed to the 851-854 segment assigned to the other sites.
Thanks for the update on the target date for RCS North.
If I understand correctly from another random RR post, the system will spit out a status bit for rebanding in progress prior to the switchover, and at that point, the new/custom/rebanded bandplan will work with the current 863.15 CC and seamlessly continue to work when the reband happens? this is how it happened on the South site.
Paul
Actually, no. Without getting into the very dry technical reason, we will turn off half of the channels and retune them, then turn them back on while shutting of the remaining channels and retuning them.
I'm working with user groups to reduce the traffic on the cell during the process.
Don
