Hello,
I just got my phase 2 G5 and have been playing around with it on my local VHF P25 system. One thing I noticed is that if I have a TG programmed that is normally patched, the G5 doesn't seem to recognize activity on that TG.
I'm probably not explaining it very well, but for example, on my local system the Fire Dispatch TG is 6505. According to pro96Com, it appears that every time there is a call on this TG, it is actually patched from a different TG, in my case TG 6502 on the site I am monitoring. I would like to program a knob position to monitor only activity on TG 6505. However, when I setup a knob position as such it never stops on any transmissions. If I program in the "source" TG 6502, then it does stop on the dispatch transmissions however 6502 is also the TAC channel for my area so I also get all the other traffic on that TG.
Has anyone run across this before and if so, is there a specific setting within PPS to allow a patched TG to be recognized?
I did confirm that I have Alert Mode set to Tone in the knob position setting I have setup for this TG.
It's not a real big deal because I can just use TG 6502, but I was hoping to dedicate a knob position to just the dispatch calls and nothing else.
Thanks.
Thanks.
