My apologies if this has been discussed before. I think I have found another reason to stick with my whistler trx-1. It seems as though, at least in the sentinel software and attempts on manual entry, that one cannot put an analog frequency in the same list as a set of talkgroups.
In other words, the city where I live has a Motorola Smartnet system currently and uses Analog talkgroups on their radio and when the system fails even then to get inside a building, they go to a couple of analog talkaround channels that are analog. Namely 800 mhz analog. Because the TRX-1 is object-oriented, I can add these two analog frequencies to the same scanlist as the other analog talkgroups that are on the trunked radio system.
Has anybody figured out a way to add analog frequencies to a department list that is associated with a trunked radio system and have it so that these analog frequencies are scanned when the department talkgroups are scanned?
