Not playing for me, hmm. Same errors as the OP.
ore debug: processing request item: 1 Chicago Police Live Audio Feed, node: Playlist, skip: 0
core debug: resyncing on 1 Chicago Police Live Audio Feed
core debug: 1 Chicago Police Live Audio Feed is at 0
core debug: starting playback of the new playlist item
core debug: creating new input thread
core debug: Creating an input for '1 Chicago Police Live Audio Feed'
core debug: requesting art for 1 Chicago Police Live Audio Feed
core debug: using timeshift granularity of 50 MiB, in path 'C:\Users\bobdog\AppData\Local\Temp'
core debug: `
http://listen.broadcastify.com:80?t...6DA3D7878702E768B57855C47D68187A09B01D2FD52AF' gives access `http' demux `' path `listen.broadcastify.com:80?t=BCE52C2F33D36E36AEE910D47BAB3B20C2E17F896DEF617602A6DA3D7878702E768B57855C47D68187A09B01D2FD52AF'
core debug: specified demux `any'
core debug: creating demux: access='http' demux='any' location='listen.broadcastify.com:80?t=BCE52C2F33D36E36AEE910D47BAB3B20C2E17F896DEF617602A6DA3D7878702E768B57855C47D68187A09B01D2FD52AF' file='\\listen.broadcastify.com:80?t=BCE52C2F33D36E36AEE910D47BAB3B20C2E17F896DEF617602A6DA3D7878702E768B57855C47D68187A09B01D2FD52AF'
core debug: looking for access_demux module matching "http": 12 candidates
core debug: no access_demux modules matched
core debug: looking for meta fetcher module matching "any": 1 candidates
core debug: creating access 'http' location='listen.broadcastify.com:80?t=BCE52C2F33D36E36AEE910D47BAB3B20C2E17F896DEF617602A6DA3D7878702E768B57855C47D68187A09B01D2FD52AF', path='\\listen.broadcastify.com:80?t=BCE52C2F33D36E36AEE910D47BAB3B20C2E17F896DEF617602A6DA3D7878702E768B57855C47D68187A09B01D2FD52AF'
core debug: looking for access module matching "http": 21 candidates
http debug: querying proxy for
http debug: no proxy
http debug: http: server='listen.broadcastify.com' port=80 file=''
lua debug: Trying Lua scripts in C:\Users\bobdog\AppData\Roaming\vlc\lua\meta\fetcher
lua debug: Trying Lua scripts in C:\Program Files (x86)\VideoLAN\VLC\lua\meta\fetcher
core debug: net: connecting to listen.broadcastify.com port 80
lua debug: Trying Lua playlist script C:\Program Files (x86)\VideoLAN\VLC\lua\meta\fetcher\tvrage.luac
lua debug: skipping script (unmatched scope) C:\Program Files (x86)\VideoLAN\VLC\lua\meta\fetcher\tvrage.luac
core debug: no meta fetcher modules matched
core debug: searching art for Chicago Police Live Audio Feed
core debug: looking for art finder module matching "any": 2 candidates
lua debug: Trying Lua scripts in C:\Users\bobdog\AppData\Roaming\vlc\lua\meta\art
lua debug: Trying Lua scripts in C:\Program Files (x86)\VideoLAN\VLC\lua\meta\art
lua debug: Trying Lua playlist script C:\Program Files (x86)\VideoLAN\VLC\lua\meta\art\00_musicbrainz.luac
lua debug: skipping script (unmatched scope) C:\Program Files (x86)\VideoLAN\VLC\lua\meta\art\00_musicbrainz.luac
lua debug: Trying Lua playlist script C:\Program Files (x86)\VideoLAN\VLC\lua\meta\art\01_googleimage.luac
lua debug: skipping script (unmatched scope) C:\Program Files (x86)\VideoLAN\VLC\lua\meta\art\01_googleimage.luac
lua debug: Trying Lua playlist script C:\Program Files (x86)\VideoLAN\VLC\lua\meta\art\02_frenchtv.luac
lua debug: skipping script (unmatched scope) C:\Program Files (x86)\VideoLAN\VLC\lua\meta\art\02_frenchtv.luac
lua debug: Trying Lua playlist script C:\Program Files (x86)\VideoLAN\VLC\lua\meta\art\03_lastfm.luac
lua debug: skipping script (unmatched scope) C:\Program Files (x86)\VideoLAN\VLC\lua\meta\art\03_lastfm.luac
core debug: no art finder modules matched
core debug: art not found for 1 Chicago Police Live Audio Feed
qt4 debug: IM: Setting an input
core debug: connection succeeded (socket = 2128)
http debug: protocol 'HTTP' answer code 416
http error: error: HTTP/1.1 416 Requested Range Not Satisfiable
http debug: switching to HTTP version 1.0
core debug: connection succeeded (socket = 2168)
http debug: protocol 'HTTP' answer code 200
http debug: response body size=0
http debug: Content-Type: text/html
http debug: Server: Tips are accepted
http debug: Connection: close
core debug: using access module "http"
core debug: Using stream method for AStream*
core debug: starting pre-buffering
core error: cannot pre fill buffer
core debug: removing module "http"
core warning: cannot create a stream_t from access
core debug: finished input
core debug: dead input
core debug: changing item without a request (current 0/1)
core debug: nothing to play
qt4 debug: IM: Deleting the input
Mike
