HT 1000 Programming Error Message
caerickson
Phoenix, Arizona
I'm trying to program some HT 1000 portables using the Motorola RSS software. The software is installed on an old laptop running Windows 98 and I'm running it in DOS mode. The software seems to be working normally except when I try to download the code plug and I get a message that the program is waiting for a reset from the radio and then a message that says TSR Background Program Interference or Temporary High Noise/Traffic Level. Prior to the message appearing there is a beep from the portable indicating that it is connected to the program.
Has anyone experienced this type of issue and if so how did you resolve it. Any information will be appreciated.
Thank you
caerickson
Phoenix, Arizona
The RSS program has an MS DOS HT1000 Icon. I hit the icon and the program booted up. I will try the F8 key and see what happens.
Thank you for your response.
caerickson
Phoenix, Arizona
The F8 key didn't work during the boot up. The computer I'm using is set up to run Kenwood DOS programs and has an option to switch to a C: prompt. I started the program from the MRSS directory and it worked great. The program looks exactly the same when started in Windows 98 command prompt and when started in DOS without letting Windows start up.
Thank you for your great advice. The 6 radios are programmed and headed to the field.
nokones
Sun City West, AZ
With Windows 98 you have to shut down the computer by using the "Shut Down Windows and Restart in MS DOS mode" in order for the radio to communicate with the RSS.
