Post Not Showing on the Today,s Post Pages
ipfd320
Banned
W.Babylon N.Y. 11704
I Put a Post in the Everything Else Section of the Forum about the Vero Beach Air Show This Weekend Due to it may Fall into 2 Other Forum Area,s --This was Posted at 11:29 pm Last Night (4/18/2018)--The Posting is Not Showing Up on the (Posts From Last Day--Todays Posts Tab Pages)--Curious to Know Why its Not On There for the Rest of the Community to See--Instead its Burried for a Very Few to See--Can a Moderator or Admin Move the Post to Florida Monitoring or Something for the Users to Comment and Post On
Thanks--
MtnBiker2005
San Diego County, California
What link are you using?
Check the exclude numbers on the end of the URL.
Try using this link to see all the new updated threads with new posts for the whole forum.
http://forums.radioreference.com/search.php?do=getdaily
Sounds like the link you are using includes one of the forum area exclude number. (#168 = everything else) area. This is the link that's hard coded on top of the forum page. So it's excluding 10 forum area from that search.
https://forums.radioreference.com/s...xclude=160,161,162,168,77,157,156,155,154,148
See this post for the forum area numbers to edit the link you want to use.
https://forums.radioreference.com/forums-administration/19685-rss-access-forums.html
mikewazowski
Staff member
Forums Manager
Oot and Aboot
If it's in the Tavern than most likely it won't show up on the Today's posts.
Report the post and a Moderator will move it to a better forum.
Thanks.
fxdscon
¯\_(ツ)_/¯
Thanks--
Click the 1st link given in post #2 above. As mentioned, that will list all forums without exclusion. Your post does show up there, but at this time it's already down on page 5 because of newer posts chronologically on top of yours.
ipfd320
Banned
Thanks.
Hey Mike Yes its in the Tavern---I Dont Know How to Report it or Even Where to Start---Is There Anyway You Can Move It to the Appropiate Area it Needs to Be In--It Would Be Much Appreciated
fxdscon
¯\_(ツ)_/¯
Click the little triangle just above where it shows your zip code at the top of every post you make. Click that triangle on the post you want moved.
