Hello. I'm running Unitrunker with an AirSpy. I have everything up and running fine, can decode my control channel, see calls being made, decode P25 voice with DSD+, etc. The system is a Motorola Type II SmartZone.
The scanner will run perfectly fine for a seemingly random amount of time, sometimes 5 to 10 seconds, other times for multiple minutes. However, after a while, I lose the control channel decoding entirely.
I can see on the VCO Scope for the control channel that it switches from a normal looking signal (top image) to one that's all wonky (bottom image).
I've tried de-selecting all but the Motorola protocol for the Signal VCO and turning off Discover. Chase is also off. The receiver is set with only 2 VCOs, one for signal and one for voice.
I've also tried moving the SDR to connect directly to the computer USB and bypassing a USB hub. The latter may have helped a bit but I'm still experiencing occasional signal channel loss.
Any thoughts?
Thanks!
Any thoughts?
Thanks!
