Forum images max-width
K7MFC
WRAA720
Phx, AZ
I've noticed that when very large images are posted in the threads, it blows the width of the the parent <tr> element way out, making it necessary to scroll horizontally and vertically to read the thread. Tested in all browsers - example thread:
https://forums.radioreference.com/r...ion-forum/369372-2018-ford-f-350-install.html
Can I suggest adding a "max-width: 100%" property to any img in a post_message div? There are still some additional style related issues when very large images are posted, but this would be a quick and easy fix to make the forums a bit more navigable.
fxdscon
¯\_(ツ)_/¯
Changes to the entire forum structure may be coming soon:
https://forums.radioreference.com/f...n-posting-messages-elsewhere.html#post2914339
mciupa
Moderator
I find that situation annoying in the forums I moderate. I hate to scroll all over the page. Post #2 in that referenced thread is the worst I've seen.
My remedy is to edit the post and remove the
codes from the post which will render it as a https: link to be clicked on.
That's my post, and I edited the first one to the option I had that would fit. The sizing seems to be an Imgur thing that I need to play with.
The second one is just because I forgot to downsize it. I'll fix it now.
It's always OK to PM me directly with stuff like this and I'll be happy to address it.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
It's easiest if the poster resizes the image to something more suitable for the forums.
Unfortunately, most don't so we change the picture to a link.
K7MFC
WRAA720
Phx, AZ
My inquiry wasn't necessarily about that particular post - it just happened to be the most recent example that exposes this issue. A user should not have to worry about image size when posting a direct image link - that should be handled by the site via proper styling. In a perfect world, users would be cognizant of this and post appropriately sized images, but as MikeOxlong mentioned, this is not always the case. Applying a max-width property so an <img> element fits the width of its parent should be a straightforward fix.
edit:
To demonstrate, here's how the page displays when I apply "max-width: 100%" globally to all <img> elements - no change to the original images is necessary:
before:
after:
I reposted and fixed the image size to something more reasonable, half the size of what they were before. I tagged the original posts for moderate deletion, if one of you would be so kind. Everything is now on one post.
Also,
I searched the site using the FAQ search for something regarding suggested image size, but I couldn't find it. If there's a page that addresses that, It'd be helpful for someone to point me at it so I can make sure my future photos are the recommended size.
fxdscon
¯\_(ツ)_/¯
Also,
Don't know if these are hard-coded limitations, or suggestions. This is from the pop-up window when you click the "Attachments" icon (the paper clip) when replying to a post....
K7MFC
WRAA720
Phx, AZ
This applies to images that are attached by the user and uploaded to RR's storage. The issue here is when images from an external host are displayed in the forums. There is no limit on the size of these images, as radioreference is not hosting or processing them on their servers.
fxdscon
¯\_(ツ)_/¯
I am aware of the difference between attached images and those hosted externally. Perhaps following the max height and width sizes suggested here would prevent the post from expanding beyond it's normal width.
(Which was the question asked in post #7).
K7MFC
WRAA720
Phx, AZ
Ah, gotcha. Ideally yes, users should be aware of the size of images they are posting. But in all practically, they aren't aware and/or don't care. I would strongly urge the site admins/devs to implement one line of CSS and fix the root cause of this issue, rather than relying on users to post images of a certain size, or relying on admins to spot these issues and edit the post to change the <img> element to a link..
I was aware and did fix the first post. It was the following one where I just plum forgot. However some may not or don't.
Which seems like a much better solution than:
...relying on admins to spot these issues and edit the post to change the <img> element to a link..
Removing the <img> would require viewers to click on each individual link, which takes a lot of convenience out of this board. I don't like clicking on unknown links all the time, either.
But sounds like a fix is in the works. We can wait and see what the solution is.
fxdscon
¯\_(ツ)_/¯
Perhaps when the upcoming new forum software is deployed it will address that issue. I agree, it is annoying when the current software allows that to happen.
K7MFC
WRAA720
Phx, AZ
For any Stylish users out there, I made a really simple custom theme that will fix the image width problem:
RadioReference Forums - userstyles.org
Stylish is a cool browser extension for Chrome and Firefox which allows a user to apply a custom style to a website, modifying the way the content like text and images are displayed within their browser. The theme I created will prevent an image in a post reply from exceeding the default width and eliminate the need for horizontal scrolling to view replies.
The actual CSS change I make to fix image dispaly is the following:
Code:
div[id^='post_message'] img
    max-width: 100%
K7MFC
WRAA720
Phx, AZ
I recently learned that the Stylish browser extension I recommended above was found to now contain spyware that can track your web browsing behaviors:
https://robertheaton.com/2018/07/02/stylish-browser-extension-steals-your-internet-history/
If you you currently use the Stylish extensions/add-on form Chrome or Firefox, it is recommended you remove it immediately! Here is some information on how to render custom CSS for a site in Firefox and achieve the same result without the need for the Stylish add-on:
https://superuser.com/questions/318...css-of-a-site-in-firefox-with-usercontent-css
