I have a 1095 Whistler. I have tried to program Mototrbo frequencies in the scanner. I have tried entering it as trunk Freq. but won't work. Can this even be done or do I have to get an update scanner. any help will be great.
Questions about the frequencies you are trying to monitor:
- Are you using the correct color code and slot?
- Is the repeater set to use RAS? (I’m having this issue with my TRX-2, and have a separate thread and ticket in with Whistler regarding it)
- Do you have a specific Talkgroup you are monitoring, or do you have the object set for “any”?
- Does monitoring the frequency directly (make sure DMR is enabled) produce any results?
