XPR 5550 Transmission issue
caphab1
Mesa, AZ
Hey All
Just finished programming my XPR 5550 and having some difficulties. Tried to do some internet digging but only seeing people with the same issues but no reslove.
On a couple different sites using the same TG, I see transmissions happening and radio IDs but not hearing any audio. Can someone clarify my programming is done correctly? Do I need to have a Channel Pool set up? Is this an RSSI issue or Admit criteria issue? I know CCs and TS's are correct.
Thanks!
thassler
Tennessee
Under "General Settings", what is your radio id? Some will leave their radio id to the default of "1". Radios with the same id will not pass audio.
caphab1
Mesa, AZ
I've also changed my radio id to dmr Marc network id
Sent from my Pixel 2 using Tapatalk
thassler
Tennessee
Nope. All 6 of my DMR radios talk to each other using the same ID number.
That's curious because on our IPSC system that's a trick we use for backup radios in dispatch. We give the backup mobile the same radio id as the console's control station and when the dispatcher keys the console the audio doesn't come across the backup mobile. The talkgroup id shows but no audio comes across. Of course the CAI network has to be the same....
btromp
Eastlake, OH
Same ID numbers will work on conventional digital simplex or repeater channels but on any of the other advanced system types(IPSC, Cap+, etc), it is as you say: a receive radio with the same ID as the transmitting radio does not unmute and pass audio.
Sent from my iPad using Tapatalk
