Yes, but emphase is on little. 10 connectors in series put on an analyzer didn't show any measurable attenuation I.E less than 0,1dB. The problem are if a connector gets corroded from wheather or if it is of a bad mechanical design that could make a bad connect when stressed sideways.
When I buy cheap chinese adaptors in a 10-pack I usually have to discard 2-3 of them when I test them listningen to a constant weak carrier on a scanner and wiggle the connector and there is noticable change in the signal strenght.
/Ubbe
