Almost a year back, I bought 4 Midland frs radios to use for on jobsite. They have worked reasonably good for our purposes, but they aren't the most durable things, and the 3 that still work are all a bit beat up. I'd like to upgrade to a better radio. I've never had a problem with range, even with the Midland radios turned to the lowest power setting to conserve battery. A couple hundred yards is plenty for what we are using them for. I would like a little better sound quality, as well as the ability to scan several channels, so that the guy giving crane commands can be on a separate channel with the crane operator, and not clogging up the main channel, but I can still call out to the entire crew and be received by everyone. I know that a lot of the programmable radios like the Motorola cp200 can do this, but I'd like to avoid dealing with the FCC if possible. Any suggestions?
