Mike445
Has anybody else noticed that the OPP are also using MTO enforcement talkgroups? For example 3904.
They are commonly patched together due to the fact MTO officers need to talk to OPP sometimes. Furthermore, they don't have the own dispatcher(s) so OPP dispatchers also communicate with MTO officers.
Sent from my SM-A520W using Tapatalk
MTO have been patched with OPP for over a year now.. Least in my area. Same with the MNR guys. MNR callsigns are Romeo (R for resource). MTO are Tango (T for Transportation)
Not quite that simple throughout the province.MTO have been patched with OPP for over a year now.. Least in my area. Same with the MNR guys. MNR callsigns are Romeo (R for resource). MTO are Tango (T for Transportation)
Tango call signs are used for OPP in Wellington County.
Romeo call signs are used for OPP in Bruce County.
The talkgroup or alpha tag should help determining who your hearing.
Not all the time do you hear 6 Tango or 6 Romeo used.Wellington County is 6 Tango, Bruce is 6 Romeo (the 6 indicating West Region) while MTO/MNR are just Tango and Romeo.
Sent from my SM-T710 using Tapatalk
Quite often it will be dispatched as Tango 101 ect.
The reason I stated checking the talk group or alpha tag.
And on another topic it seems EMS never uses the hospitals own talkgroups for patches but instead EMS Tac 4 (at least in Hamilton)
I disagree. The London and Orillia dispatchers will always use the 5 or 1 or 6 before the Soft id of the unit. The individual cars might not be so anal thou. MTOE units dispatched by Orillia have their first numeral 2, London dispatch MTOE units start with a 3.
Its one of those things that if you listen enough you pick it up. Does the original poster of this thread have a scanner with radio ID listed or an older one? MTOE for the most part have radios in around the upper 3000's low 4000's like 3927, 4003, 3811, ETC.
I think Mike445 gets the idea now
Id say 80% of the time London Comm will use the 6 when calling units. When having a few transmissions in a row with the same unit they drop the 6, but use it again when calling a new unit or after a little time gap between the original unit.
Its all due to recording of the radio traffic. That 1% chance something happens and the "tapes" get played back and London didnt use "6" to call a unit im sure someone someplace would make a issue of that
As for the Tango/Romeo units i hear them calling in as Tango 3506 or Romeo 508 so on and on. I hear both MTO and MNR on the OPP talkgroups, and otherway around. OPP on the MNR/MTO groups due to them patched.
