MDC1200 preamble
Will001
Lexington County, SC
So I’ve heard the MDC1200 “preamble” before, and I’ve always wondered what it is. I think I heard something about it letting you put more characters for the ID, but I’m definitely not an expert. Also, is there a way to program a XTS5000 with this format? Or is it for older radios only?
By the way, if anyone wants to know what it sounds like, here is the link: http://www.w2sjw.com/sounds/MDC1200 Preamble.mp3
bk117
Philadelphia
Preamble is used so that all radios on a particular channel have time to sync up. Preamble is simply a packet of sync bits that are sent prior to the actual ID, this will give a repeater with a longer on-delay time to come up or operate correctly on a simulcast conventional system.
All Motorola Radio’s with MDC capability have adjustable preamble and pre-time.
Will001
How would I go about programming this? I have to have it because I’m working with a company this summer that uses that signaling format.
Toppis98
Asbury Park,NJ
How were you able to program this onto the radio. I have a XPR 6550 and a XPR 7550e that I would like to add this to but do not know how.
K2NEC
Go to Signaling Systems>MDC>Sys # Then find "Preamble Bit Sync" Should be the 6th box down. You can change this to anything from 1 to 96
