If you shut the scanner off by pulling batteries, you will lose all setting changes made since the last normal power down. Setting changes are saved to the memory card during power down.
If the card is going bad, you will have the same issue, setting changes aren't saved due to card error.
Try a different card and don't just pull power to shut down.
