I have a BCD436HP and currently am using a back of set Harvest SMA24 dual band Flexible VHF/UHF Dualband Antenna (SMA-male), specs pasted below. My local frequencies are mostly P25 (don't know if I or II). Would I benefit from having an 800Mhz (like the RS800) instead? If I don't care about VHF stuff, etc?
Specs of current whip antenna:
Frequency Range: 144/430Mhz (2M / 70Cm)
Impedance: 50 ohm
Gain 2.15dB(145mhz), 3.4dB(435mhz)
Max Power: 20 Watts
V.S.W.R . less than 1.5 Length: 15.7 inch (40cm) Connector: SMA Male
Impedance: 50 ohm
Max Power: 20 Watts
