trx680
I know at least a few of you here have this radio, as it was recommended.
So I'm going to give this one a try, actually for my son. He will use it mobile in his Honda CRZ.
Other than the radio, what do you recommend as far as accessories? He will need to mount it in his car. Not 100% sure where in the car we will mount it yet. I see the faceplate is removable and can be located separately. Most likely will place the main body under the front seat and mount the faceplate where he can easily have access to it.
Will go with a magnetic antenna for the roof.
What connection will I need for this radio? See the link below.
https://www.theantennafarm.com/catalog/mobile-antenna-mounts-264/magnetic-mounts-265/
And as far as the whip. A high-gain dual band?
There's a lot to chose from. Suggestions?
https://www.theantennafarm.com/cata...al-band-450/high-gain-dual-band-antennas-453/
So need:
- A cable to relocate the faceplate. https://www.dxengineering.com/parts/ysu-ct-162
- A mount for the faceplate. https://www.gigaparts.com/ram-universal-x-grip-cell-w-twist-lock-suction-cup.html
- I think it comes with a computer cable, but I need programming software? https://www.gigaparts.com/rt-systems-software-m100.html https://www.hamradio.com/detail.cfm?pid=H0-014322
- External speaker (let me know it theres a better one) https://www.dxengineering.com/searc...r&sortby=BestKeywordMatch&sortorder=Ascending
Below are three retailers with accessories.
https://www.hamradio.com/detail.cfm?pid=71-002024
https://www.gigaparts.com/yaesu-ftm-100dr-50w-2m-70cm-mobile.html
What do you think? Put together a list for me for my son's first radio. I'm going order this soon, probably tomorrow.
THANKS!!!!!
So need:
THANKS!!!!!
