I am using my Uniden 325P2 with DMR upgrade attempting to monitor a local DMR Tier 3 system. I live within line of sight of the transmitter so signal strength is not an issue.
There are only three frequencies, the system is https://www.radioreference.com/apps/db/?sid=9138 . There are no LCNs listed in the database, so I have used 1, 2, 3 for the frequencies in the order listed. I get a solid lock on the control channel.
What I hear are partial convesations. For example, I can "hold" on the Ops 2 talkgroup and I might hear a mobile unit say "Go ahead" as if he was called by dispatch, though I never heard dispatch. Then after the "Go ahead' I usually hear nothing else, though presumably there is an interactive conversation back and forth between the unit and dispatch.
I do not understand the nuances of DMR, but have fiddled around with the LCN order etc, and am having no luck at all on really hearing the system.
Any suggestions greatly appreciated.
