The 7900 has a transmit frequency range of 144.000 to 148.000MHz and 430.000 to 450.000MHz.
If your departments frequencies are outside that range, then the radio will not transmit there.
The Yaesu FT-7900 is an amateur radio, it does not have the FCC type certification to transmit outside the amateur radio bands.
The FCC Part 90 rules that your departments licenses is granted under strictly forbids transmitting with radios that do not have the FCC Part 90 type certification.
Using this radio on your departments frequencies and under their license puts not only yourself, but your department on the wrong side of the FCC rules. Law enforcement, fire, EMS, other public safety agencies, public works, etc are not exempt from these rules. As an amateur radio operator, your license does not give you permission to transmit outside the amateur radio bands.
To transmit on your departments frequencies, you need to have permission from the person who is directly responsible for the FCC licenses, and you need to have a radio that meets the FCC Part 90 requirements.
Your radio will work fine for amateur radio frequencies, but using it outside those frequencies runs afoul of the rules.
If you need a recommendation for a radio that will work legally on those frequencies, we'd be happy to make some recommendations.
