I have had trouble with an annoying loud buzzing across the MW broadcast band inside and outside my QTH for the past six weeks. It appeared suddenly and basically wiped out most AM stations with the exception of very strong ones. So, after walking around the house with my radio it was apparent that the noise was being transmitted through the house wiring. The culprit was my weed whacker's battery charger that was in the garage. The noise was present when charging the battery and even when the charger was plugged in but without the battery inserted. Unplugging it was the answer.
Is there any way to prevent an appliance from causing interference through the house wiring? This device is apparently doing this. Thanks.
