Hi all,
I'm from the Netherlands and have the DV10 now for 2 weeks. I did not test he HF side of the radio but mainly the VHF/UHF side and compared it mainly against the Uniden 3600XLT and whistler TRX2.
Sadly I have to say i'm not impressed at all, If I program the scanner with the same frequencies as the other 2 scanners I noticed the DV10 misses up to 60% of the transmissions the other scanner catch easily. all these scanner are on it's stock antenna.
If I use a different antenna on the DV10(like a stock Uniden one), it roughly misses 35% of the transmissions, so a little improvement there.... for what s meter are worth you can clearly see the DV10 is always behind on signal strength.. and this inst a small difference either..
The DV10 also seems to lack some shielding, some might consider this reasonable given its size and capabilities, But this seems to cause unwanted behaviour like being picked up by other scanners within a range of 2 meter. Other thing I noticed is it sometimes receives its own.
If I leave the scanner in auto mode, it sometimes produces a what sounds like a disorted digital signal.. even if take the antenna of, put NSQ up to 35 and place the radio in the closed tin can, it still seems to do this, which lead me to think its picking up its own noise..
Regarding DMR, the DV10 seem to need a much stronger signal then for example the 3600XLT does.. The transmissions i can hear on the my other scanner dont seem to be decoded by the DV10, sometimes it might see the wrong colour code, but thats it.. no audo.
So, it looks like a nice device but how it currently performs versus it's price point.. I would not recommend it. Maybe overtime AOR fixes some of the issues, but that isn't guaranteed.
There is facebook group called "AOR AR-DV10 Digital Receiver" where you can find some of my test videos. Now everyone might have a different opinion on how solid these test are, but I felt like I had to share them.
