- Joined
- Jun 26, 2006
- Messages
- 143
Apologies if this has been answered, searching for anything I could try just turns up a lot of discussion about using established software to program the scanner over the serial port.
Is the protocol used on the serial port documented? I'd be interested in writing a little script to show what channel the scanner is currently on, and perhaps toggle scan/hold. Curious if anyone has done this before and if it's an open/documented protocol. (My master plan, which I haven't started working on, is a sort of mic switch for a few radios with a small LCD character display that could maybe act as a limited remote head.)
I have the BCD536HP but assume (and you know what they say about assuming...) the serial interface is similar across most modern Uniden scanners?
