baofang uv-8r
swemt
LAke harmony
Help
Just purchased this radio because in needed the 500-520MHZ range , but I cant find any software to program the chirp doesn't work . I have tried multiple version on different radios but no luck. I have emailed baofang tech but , no luck there either.
It can be done a few have done but no one is sharing the secret. Please help or suggest anther dual band radio with the same capabilities.
Any suggestions.
Scott
swemt
LAke harmony
uv-8y
It just wont read or write not sure if its a bad connection or a bad radio.
Scott
jonwienke
More Info Coming Soon!
VA
There are a lot of cheap Baofeng cables out there with fake Prolific chips in them that simply do not work. Make sure your programming cable has a FTDI serial-USB chip in it or you will likely have nothing but trouble.
SpugEddy
Camden County South Jersey
Yes. Also, I installed the prolific drivers, then had to uninstall and
roll back the driver to an earlier version.
After plugging in your cable, go to device manager
Go to Ports (Com & LPT) and expand it
The Prolific driver should be listed there along with the
assigned COM Port #
(example) Prolific USB-to-Serial Comm Port (COM2)
then go into chirp and make sure you set the COM port to 2 (or whatever
port your cable is assigned to)
