Ncfirewire
- Joined
- Feb 17, 2012
- Messages
- 236
On my Counties system in Niagara County NY which is a P25 Phase 1 trunking Simulcast system. Every previous digital scanner started to lose transmission entirely once i hit the southern border of the county. So I purchased a Unication g5 pager 6 months ago and instantly the problem was fixed i could even drive as far as 35 plus miles outside of the County border and it still worked perfectly.
Today i programmed a new sds100 for a friend and then i took the sds100 & the G5 on a road trip. I got to the county line (same spot where by bcd436 died) and the sds100 was loud and clear but once i got about 3 to 4 miles south of the county line I started to set garbled transmissions and when i got about 5 to 6 miles south of the county line i lost everything entirely on the sds100 and the G5 was still working perfectly.
I will say the sds100 beats any previous scanner as long as i was within county lines as it works perfectly so i would give the scanner 10 out of 10 to use inside my county & inside of my house. For traveling i would only give it a 2 of 10 and i would not purchase the sds100 to use as a portable as it just doesn't match the distance that my G5 gives me once i leave the county lines. Maybe it will later change with firmware updates and i will update it again after i program another one.
Just my 2 cents
Just my 2 cents
