LCN finder can time time - the busiest the system, the faster the results ... slower - well, you get it.
4/5 is pretty good and if that happened quickly, chances are, the 5 frequency is either wrong or not part of the system. What do you hear on that 5th frequency when programmed as conventional (if you look at the programming after storing the LCN finder results, one frequency should probably still have an LCN of 0).
You can monitor with 4/5 for a while and assuming it is a strong system and being received well, you should be able to determine (based on missed conversations/replies) if you have all the frequencies.
