My question is...…..Anybody have any idea how I can get a CB Radio installed in my 2013 Ford F150 truck?
Welcome, Mike.
I had a 2011 F150 up until a few months ago. I had a VHF mobile and an 800MHz mobile in it. About two years ago I was making a trip from California to Denver and back as well as one from California to San Antonio and back. I pulled the 800MHz radio out (had to put it in one of my work trucks) and put a CB in it's place.
The good part is that these full size American pickups are really easy to install radios in.
Due to all my radios being a remote head type with the control head under the dash and the RF deck behind the back seat, it was pretty easy. When I put the CB in, I went with a Uniden CMX560, which is a remote head radio.
Depending on what type of CB you want to install, it'll dictate how and where you mount it. Your cab and seat type will impact things, too.
What I can tell you is what applies to all radio installations:
Don't cut corners on the installation. In other words, going cheap and easy usually gets you a poor performing set up. If you are serious about having the radio work well, you'll need to get beyond mag mount CB antennas and cigarette lighter plugs.
Clean power is important. Do not tap into existing vehicle wiring for the radio power. Always run your radio power feed directly. Put the positive lead on the positive terminal of the battery with a fuse close by to protect the rest of the wire. Connect your negative lead to the vehicle chassis as close as you can reasonably get it to the CB.
And never skimp on the antenna. There are a lot of cheap and crappy CB antennas out there. If you purchase a CB antenna based on looks alone, chances are you will be disappointed. Understanding that CB's need a big antenna mounted in the center of the cab roof is a good thing to wrap your mind around before you get started.
I used a Larsen NMO-27 antenna mounted on a permanent NMO mount on the center of the cab roof.
Putting the antenna in the center of the roof gets you the best possible ground plane around the base of the antenna. That's important for a number of reasons. Most of all, it gets you a nice clean radiation pattern, which means you are getting equal amounts of signal out in all directions.
The Larsen antennas are very durable. I've had the same one for going on 25 years now, and I pretty much exclusively use their antennas for work. You won't find them at Wal*Mart or your local truck stop. They are a commercial antenna designed for commercial use.
The antenna mount is important, too. Installing a good NMO style mount gives you a great starting point. While it can be hard for newcomers to understand the importance of doing a permanent installation, I've never had one let me down.
I can probably dig up a few photos of my install if you'd like.
If you can share some info about what your expectations are about range, performance, etc. as well as what your skill level and budget is, that would help us help you.
