XPR5550e code Plug
jeffpugh
St.Maries Idaho
Searching for a code plug for a XPR5550e Model Number AAM28TRN9KA1AN I need to reset the PW and the The sample file I have does not match the Model number. Thanks in advance.
rescue674aa
I’m an idiot
Use the sample codeplug and clone it.
alcahuete
Antelope Acres, California
Your problem is that the model number you list is not an 'e' model. It's an older standard model, if I'm not mistaken.
AAM28TRN9KA1AN 450-512 MHz, 1-40 Watts, 1000 Channels
If this is the one that was recently up on eBay, it was mis-listed. I wrote the seller, but never heard back, and never bothered looking if the listing was corrected.
Unfortunately, I only have a VHF and 430-470 bandsplit codeplug for that radio, which I don't belive will work. Will a hex edited one work? Hmmmmm...I don't know.
N1GTL
CT
Why not just do a "recovery"? Wipes the radio and installs new firmware. TT
Ummm...this! Besides, if the radio is password protected, you usually can't even write a code plug to it.
jeffpugh
St.Maries Idaho
Tried the sample code plug. don't work radio model number does not match. Tried to restore that didn't work either. Taking it to the the local Motorola shop I will update when I get it back.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
Can you explain what steps you took and any error messages you received? Trying to clone or write over the top of a password protected radio will not work. These are not Kenwood or Waris series radios. No password, no workie. The only way around it is to perform a recovery, send it to the depot, or pay for the radio unlock EID from mother Moto. The recovery is the easiest, but requires you to have the same or newer firmware version installed into the CPS of the radio you are trying to recover. Do you have the firmware installed? TT
