Received a loaner SDS-100 today (out of the box, first impression - no better than any other radio I have for what I monitor) --
Anyway, thinking about trying the beta f/w but want to be able to get back to the latest "release" f/w if/when I do for various tests/systems/scenarios .... Options?
The location indicated by Jon is the location of the last firmware update applied via Sentinel on your PC. That would include the 436/536HP.
However, since you have a 'loaner' SDS100, which you probably have not updated it's firmware via Sentinel, that may not work for you. However, if you have a blank, spare, micro-SD card, you can work around that.
The only official update for the SDS100, applied via Sentinel, is SDS100-_V1_02._03.bin. Take a blank card, use the clear user data option (select 'show all drives'), then select Update Firmware. You'll get a prompt to select which model, so select the SDS100. That will copy the firmware file into the firmware folder on the card. You can then copy the folder contents to your PC to use for reverting from the beta file if so desired.
